- First time setup
- Button Mapping
- Link Multiple Haptique
- Roku
Charging The Remote
Updated 19 Nov, 2024SpecificationsWe are offering two practical charging methods to suit your needs.
Charging Dock
The quickest and easiest way to charge your remote is by using the dedicated Charging Dock with Pogo Pins.
- How It Works : Simply place the remote on the dock. The Pogo Pins ensure a secure connection and start charging immediately.
USB-C Port for Versatile Charging
For times when you’re on the go or away from the dock, the remote also features a USB-C port for direct charging.
- How to Use It : Connect a USB-C cable to the port on the remote.
With these two convenient charging options, keeping your remote fully charged has never been simpler. Whether you’re at home or on the move, powering up your remote is effortless.
