How to Customize Haptique® Buttons Using Sequence
Updated 23 Oct, 2024
  1. Create a Sequence :
    • Open the Haptique® app on your device.
    • Start by creating a new sequence within the app. To do this, navigate to the sequence creation option.
    • Design your desired sequences by assigning commands or actions.
    • Once you are satisfied with your sequence, save it.
  2. Open the Saved Sequence :
    • After creating and saving your sequence, go back and open it again from the list of saved sequences.
    • Ensure the sequence you wish to map keys for is selected.
  3. Locate the key Mapping Option :
    • In the sequence editor,look at the top right corner of the screen. You will see a button labeled key Mapping next to the Sequence button.
    • Click on the Key Mapping option to begin customizing the buttons.
  4. Map the Desired Keys :
    • A new interface will appear, allowing you to map the keys.
    • Click on the on-screen buttons you want to assign to specific functions or actions.
    • Assign each button to the command or action you wish to associate with it. You can map these based on your preferences or needs.
  5. Save the Mapped Keys :
    • Once you have mapped all the required keys to your liking, make sure to save the changes.
    • Your customized key mappings will now be active for that sequence, and your Haptique® remote will respond according to your settings.
