- First time setup
- Button Mapping
- Link Multiple Haptique
- Roku
The Haptique® Dock : Charging and Convenience
Updated 24 Oct, 2024SpecificationsThe dock offers the following benefits :
- Easy Charging : Users simply place the RS90 & RS90x remote into the dock, eliminating the need for frequent cable plugging and unplugging. This ensures that the remote i always charged and ready to control the smart home system.
- Organized Storage : The dock serves as a designated storage spot, preventing the remote from getting lost or misplaced. It also adds a level of organization to home entertainment setups by keeping the remote in a fixed location.
RS90 Battery Replacement : Technician-Friendly Solution
For users concerned about the long-term durability of their devices, RS90 & RS90x featured a replaceable battery, but with some limitations. To replace the battery, the device must be unscrewed from the bottom, a process that requires technial expertise. While the average user may not be able to do this easily, any technician can handle the task, ensuring that the remote can continue functioning without the need for a full replacement.
- Battery Availability : Haptique® has ensured that replacement batteries will be available directly through their distribution channels, so users can easily source a new battery when needed.
RS90x : User-Replaceable Battery for Greater Convenience
RS90x, a future iteration of the RS90, addresses the desire for user-friendly battery replacement. Inspired by devices like the Fairphone, which is known for its modular, user-replaceable components, the RS90x features a user-replaceable battery. This design change will make it easier for users to swap out the battery without needing technical help or specialized tools.
- Modular Design : By incorporating a user-replaceable battery, the RS90x provide greater flexibility and convenience for users, extending the lifespan of the device without relying on technicians for routine maintenance.
- Sustainability : A user-replaceable battery aligns with current trends in sustainable technology, reducing electronic waste and encouraging consumers to keep devices for longer periods of time knowing that the battery can be easily replaced.*
