Use your Logitech Harmony Hub with the RS90
Updated 19 Nov, 2026
Keep your Harmony Hub and the activities you set up over the years, and run them from the RS90. Setup takes about a minute in the Haptique app, and the RS90 then controls the Hub directly on your home network.
Harmony Hub with the RS90 · Watch on YouTube
What you need
  • An RS90 with software 4.3 or later. It updates by itself; you can also check in Settings.
  • The latest Haptique app on your iPhone or Android phone.
  • A Logitech Harmony Hub that is already set up with your activities and devices.
  • The Hub, the RS90 and your phone on the same Wi-Fi network. Guest networks usually keep devices apart, so don't use one.
You don't need the Harmony remote or the Harmony app for day-to-day use. The RS90 talks to the Hub directly on your home network.
Set it up, step by step
1
Open Device Pool. In the Haptique app, tap Device Pool on the Dashboard. You'll see My Devices.
2
Add a new device. Tap + at the top right.
3
Pick your Hub. The app scans your network, and your Harmony Hub appears under Discovered Devices with a blue H icon. Tap it.
4
Save the Hub. The Hub's name and IP address are already filled in. Tap SAVE HUB.
Tip: reserve the Hub's IP address in your router so it never changes.
5
Find it in Device Pool. Open Device Pool and tap the H filter to show your Harmony Hub.
6
Make it a favourite. Tap the heart next to the Hub, choose the RS90 remotes that should have it, and tap SUBMIT.
7
Refresh the RS90. On the RS90 home screen, tap the refresh button (the circular arrow at the bottom). The Hub then appears with your devices. Open it, and your activities load within a few seconds.
What the RS90 can do with your Harmony Hub
ActivitiesSee all your Harmony activities, start one with a tap, see which one is running and turn everything off.
Activity remoteWhile an activity runs, the RS90's own keys (volume, channel, navigation, playback) control the devices in that activity, just like the Harmony remote.
DevicesEvery device on the Hub has its own page, with buttons sorted into Navigation, Volume, Channel, Playback, Numbers, Power, Colour buttons and Other.
MacrosUse Harmony activities and commands as steps in RS90 macros, together with your IR, Bluetooth and network devices.
StatusThe page shows when the RS90 is Connecting to the Hub, or whether an activity is Starting, Running or Stopping. When the Hub can't be reached, it says Disconnected.
Local and fastCommands go straight from the RS90 to the Hub on your network. When the RS90 wakes, it reconnects in a fraction of a second.
Good to know
  • Changed something in the Harmony app? If you added or renamed an activity or device, open the Hub on the RS90 and tap Refresh.
  • Building a macro? If a macro starts a Harmony activity and then turns it off, add a pause between the two steps. The RS90 reminds you about this.
  • The Hub doesn't report back. The Hub sends the command but can't tell whether the TV or amplifier actually obeyed. If a device doesn't respond, check that it's in view of the Hub or its IR blaster.
  • It says Disconnected or "Unable to connect". Make sure the Hub is powered and on the same Wi-Fi as the RS90 (not a guest network). If the Hub's IP address changed, check it in the Haptique app's Device Pool, then refresh the RS90.
More your RS90 can do today
Harmony is one of many systems the RS90 brings together on one screen. Recent updates added:
Smarter macros
Macros show their progress while turning on or off. A macro without its own page gets a ready-made one with playback, inputs, sound modes and power, and while one is on, a card on the Macros page takes you back to it.
Your pages, your order
Choose which pages appear, including Lighting and Rooms, and arrange them in Settings → Pages.
Quick device switching
On any device page, press the ••• key to jump to another device.
Music
Control Haptique OS music from the RS90. You'll find it in Settings.
Bluetooth TVs
With more than one Bluetooth TV, the RS90 stays with the TV you chose.
LED effects
Light effects as you swipe between pages, two new effects, and softer light for dark rooms.
Need help?
If your Hub doesn't appear or won't connect, contact our support team through the chat on this site. We're happy to help.
