- First time setup
- Button Mapping
- Link Multiple Haptique
- Roku
Home Assistant on Haptique® RS90 & RS90x
Updated 24 Oct, 2024Integrations🏠 Home Assistant Integration on Haptique® RS90 & RS90x
Features: Direct WebSocket Control via Home Assistant API
🔧 Prerequisites
- Ensure your Haptique® RS90/RS90x and your Home Assistant server are on the same local network.
- Have your Home Assistant URL (e.g., http://homeassistant.local:8123) and a valid Access Token ready.
🛠 Step-by-Step Integration Guide
1. Open Haptique Config App
- Launch the Haptique Config App on your mobile device.
- Navigate to the Device Pool tab.
2. Add Home Assistant
- Tap the “+” (Add Device) button in the bottom right.
- Select the Home Assistant icon from the device list.
3. Authenticate the Connection
- Enter your Home Assistant URL and Access Token.
- Tip: Ensure your token is long-lived and the URL includes
http://. - Tap Submit to connect.
4. Select Home Assistant Devices
- After connection, tap Select Device.
- Browse and select the devices from the list.
- Tap Save Device to complete.
5. Confirm in Device Pool
- Your selected Home Assistant device will appear in the Device Pool.
- You can now map buttons, assign to rooms, or create macros using Haptique® remote.
✅ Benefits
- Fast, real-time communication with Home Assistant using WebSocket.
- Supports control of lights, thermostats, sensors, security systems, and more.
- No extra plugins or bridges required.
⚠️ Troubleshooting
- Ensure the token is correct and long-lived.
- Verify the Haptique® and Home Assistant are on the same local network.
- Make sure Home Assistant is externally accessible if needed.
