Setting up Homey Pro Integration on Haptique RS90
Follow these steps to connect your Homey Pro to the Haptique Config App, authenticate with an API key, and select devices to control.
1 Prerequisites
Before you begin, make sure you have the following ready:
- Both your Homey Pro and the phone running the Haptique Config App are on the same Wi‑Fi network.
- Your Homey Pro’s Local IP Address.
- An Authentication API Key from your Homey account (see steps below).
2 Open Device Pool
- Launch the Haptique Config App on your mobile device.
- Tap the Device Pool tab from the main screen.
3 Add a New Device
- Tap the “+” icon in the Device Pool screen.
- Scroll to the Homey section.
- Tap the “+” icon next to the Homey label.
4 Connect to Homey Pro
In the connection setup screen, enter:
- IP Address: paste your Homey Pro’s Local IP Address.
- API Key: paste your Authentication API Key.
• How to Create an Authentication API Key
- Open your browser and visit my.homey.app.
- Log in with your Homey account credentials.
- Click the Settings (⚙️) icon in the left menu.
- Under the System tab, select API Key.
- Click New API Key.
- Give the key any name you like.
- Select the Homey checkbox.
- After creation, your API key is displayed. Copy and store it safely (e.g., in a note).
- Press Done after saving the key.
5 Finalize the Connection
- Enter the saved API Key into the API Key field in the Haptique Config App.
- Tap Save Device.
Device Connected Successfully
After saving, a confirmation will show that Homey is connected. Tap Select Devices and choose the Homey devices you want to control via Haptique. Selected devices will appear in the Device Pool, along with any associated Flow.
✓ Next Steps
- Assign the added devices to rooms from the Room tab for quick access.
- Use macros and sequences to orchestrate Homey actions with other devices.
