- First time setup
- Button Mapping
- Link Multiple Haptique
- Roku
Network Requirements for Haptique®
Updated 2 Dec, 2024SpecificationsNetwork Requirements
1. IP Address Configuration
- Haptique® Remote automatically obtain their IP addresses and other network configurations (eg., DNS,default gateway) via DHCP.
- Currently, only IPv4 is supported.
2. Subnet Configuration
- The Haptique® Remote must be on the same subnet to communicate.
- If used in a managed network environment : Ensure there are no routers or firewalls blocking communication with
- Devices should not be isolated by VLANs.
Wireless Network Requirements
1. Supported Wireless Standards
- Haptique® devices support 2.4 GHz wireless networks (IEEE802.11b/g/n)
- 5 GHz wireless networks are not supported.
2. Country-Specific Wireless Features
- The supported wireless features depend on the configured country :
- This affects the availability of higher WiFi channel (e.g. 12,13,14) which are not allowed in some countries.
3. Client Isolation
- Client isolation must be disabled in your wireless network :
- Some routers and access points have settings that prevent devices from communicating with each other, allowing access to the internet (WAN).
Network Names (SSID)
- Only network names with valid UTF-8 character sequences are supported.
- Emojis in network names are not supported, even if they appear to work.
- Hidden networks are not supported.
Security Requirements
- Supported WiFi security :
- WPA/WPA2 Personal networks.
- Open networks (without a password)
- Entreprise WiFi networks and other advanced authentication protocols are not supported.
mDNS (Multicast DNS) Requirements
Haptique® devices rely on the mDNS (multicast DNS) protocol for device discovery and communication.
mDNS Service Strings
- The following mDNS services are used by Haptique® devices :
- Haptique® Remote : _Haptique®-remote._tcp.
Domain
Devices use the .local domain for discovery.
By ensuring your network meets these requirements, your Haptique® Remote will be able to communicate seamlessly, delivering optimal performance and functionality.
