Roku IP Integration
Updated 13 Sep, 2025
Setting up Roku IP Integration on Haptique RS90 (3GB)
RS90 (1/3GB) • Roku • IP
Integrate your Roku device with IP control on RS90 and assign it to rooms for organized, seamless control.
This guide walks you through integrating a Roku device into the Haptique Config App so you can discover, control, and organize it within your rooms.
1 Prerequisites
Before you begin, confirm the following:
  • Both your Roku device and the phone running the Haptique Config App are on the same local network (Wi‑Fi or LAN).
  • Your Roku device is powered on.
  • Manual IP mode is enabled on your Roku (disable DHCP) in its network settings.
2 Open Device Pool
  1. Launch the Haptique Config App on your mobile device.
  2. Tap the Device Pool tab from the main screen.
3 Add a New Device
  1. Tap the “+” icon on the Device Pool screen.
  2. Scroll to find the Roku section.
  3. Tap the “+” icon next to the Roku label.
4 Auto‑Discovery & Connection
  1. Tap Connect to begin automatic discovery of Roku devices.
  2. Wait a few seconds for the scan to complete.
  3. When your Roku appears in the list, tap on it.
  4. Optionally, rename the device.
  5. Tap Save to add it to your Device Pool.
5 Assign to Rooms
  1. Return to the Dashboard.
  2. Open the Room tab and assign your Roku to a room for organized control.
6 Troubleshooting Auto‑Discovery
If the scan doesn’t find your Roku, try these steps:
  1. Verify Network Connection
    • Ensure both the Roku and your phone are on the same Wi‑Fi network.
    • Restart the Roku, router, or your mobile device if needed.
  2. Add Device Manually
    • If auto‑discovery fails, an Add Manually button appears — tap it.
    • On the Roku, find its IP address via Network Settings.
    • Enter that IP address into the app’s manual entry field.
    • Assign a device name and tap Submit.
Device Added Successfully
Your Roku now appears in the Device Pool of the Haptique Config App. You’re ready to control, configure, and customize it with ease.
✓ Next Steps & Control
  • From the device tile, press and hold to open Roku‑specific controls.
  • Use rooms and macros to combine Roku actions with other devices for streamlined workflows.
