Smart Light Group Support Now Available
Updated 30 Jun, 2025
This functionality allows users to manage multiple lighting devices at once — across any compatible lighting brand available in the Haptique® database. This powerful new feature makes it easier than ever to control entire rooms or zones, set ambient moods, and create synchronized lighting scenes throughout your space.
Whether you're using Philips Hue or other supported lighting systems, Haptique® automatically recognizes and groups lights based on their assigned rooms or areas. As new devices are added, groups are formed dynamically — no manual configuration required.
Automatic Grouping by Room
Light Grouping is fully automated. When you add a new light to a room using the Haptique® Config app, Haptique® assigns it to a corresponding group based on room metadata. As a result, all lights within a space — regardless of brand — are controllable as a unified group.
This ensures consistency and simplicity across your entire smart lighting setup.
Key Features & Benefits
Multi-Brand Compatibility: Group lights from any supported manufacturer — not just Philips Hue — with seamless integration.
Room-Based Grouping: Devices are automatically grouped by their assigned room or zone for intuitive control.
Enhanced Smart Environment
Light Group support brings a new level of convenience and scalability to your smart lighting setup. From homes to offices to hospitality spaces, Haptique®RS90 lets you control grouped lighting environments with greater flexibility — regardless of the brands involved.
This update extends our commitment to open compatibility and intelligent automation, giving you total control over your lighting experience.
