Setting up Smart TV Integration on Haptique RS90
Follow these steps to integrate your Smart TV with the Haptique Config App and enable remote control and automation.
1 Prerequisites
- Your Smart TV and the mobile device running the Haptique Config App are on the same local network.
- Ensure the Smart TV is powered on.
- Set the Smart TV to manual IP mode by disabling DHCP.
Supported Devices: Android TV / Projectors / Set‑Top Box / Media Player, Google TV, Samsung Tizen OS, Amazon Fire OS, LG WebOS
2 Open Device Pool
- Launch the Haptique Config App on your phone.
- Tap on the Device Pool tab from the main screen.
3 Add a New Device
- Tap the “+” icon on the Device Pool screen.
- Scroll to find the Smart TV section.
- Tap the “+” icon next to the Smart TV label.
4 Auto‑Discovery & Connection
- Tap Connect to start scanning for Smart TVs on your network.
- Wait for the scan to complete.
- When your Smart TV appears, tap it.
- Optionally rename the device.
- Tap Save to add it to your Device Pool.
5 Assign to Rooms
- Return to the Dashboard.
- Tap on the Room tab to assign your Smart TV for organized control.
6 Troubleshooting Auto‑Discovery
If your Smart TV doesn’t appear:
- Verify Network Connection: Ensure both devices are on the same Wi‑Fi network. Restart TV, router, or phone if needed.
- Add Device Manually: Tap Add Manually when prompted, locate the TV’s IP address from its Network Settings, enter it in the app, choose the Device OS, assign a name, and tap Submit.
Device Added Successfully
Your Smart TV is now listed in the Device Pool. On the Haptique Remote Device, navigate to the assigned room, hold the device button, and follow the on‑screen prompt. Enter the authentication key displayed on your TV to complete setup.
