- First time setup
- Button Mapping
- Link Multiple Haptique
- Roku
Sonos Integration with Haptique Config App
Updated 2 May, 2025IntegrationsFollow the steps below to successfully connect and control your Sonos system using the Haptique Config App.
🔧 Prerequisites
- Your mobile device (running Haptique Config App) must be connected to the Internet.
- Your Sonos speaker/player must be:
- Powered ON
- Connected to the same Wi-Fi or network
🛠 Step-by-Step Integration
1. Open Device Pool
- Launch the Haptique Config App on your mobile device.
- Tap on the Device Pool tab from the main screen.
2. Add a New Device
- Tap the "+" (Plus) icon on the Device Pool screen.
- Scroll to find the Sonos section.
- Tap the "+" (Plus) icon next to the Sonos label.
3. Authenticate with Sonos
- Tap Connect to initiate the Sonos authentication process.
- A web page will open, prompting you to log in with your Sonos credentials.
- Tap OK to authorize Haptique to control your Sonos system.
- ✅ You will see a message: "Sonos is connected."
- Tap Go Back to return.
4. Add Sonos Speakers to Haptique
- Your connected Sonos system will now be listed.
- Tap on the Sonos tab to open the device list.
- Select the speaker you wish to control via Haptique.
- Tap Add Selected System to finish integration.
- Press Back to return to the Device Pool.
✅ Final Configuration
- Your Sonos device will now appear in the Device Pool.
- You can:
- Rename the device.
- Assign it to specific rooms within the Haptique system.
- Once added, you can control the playback and speakers' volume directly from Haptique.
⚠️ Troubleshooting
- Make sure your Sonos system is powered on and connected to the same network as your mobile device.
- Double-check your Sonos account credentials when logging in.
- Ensure a stable internet connection during authentication.
- If the device doesn’t appear after login, try restarting the app and logging in again.
✅ Your Sonos system is now connected and ready to control through Haptique!
